TwinTurbo.NET: Nissan 300ZX forum - Removed the thermostat, or replaced it?
LitlElvis
on February 10, 2023 at 11:05 AM
overheating a little bit, removing thermostat fixed it
posted by tian2bing
on February 10, 2023 at 08:24 AM
If you removed it entirely, that's not good... The engine needs the thermostat to reach operating temperature quickly and get the ECU into closed loop to maximize efficiency. This would also explain why the heater is lukewarm.
tian2bing
08:24:17 02/10/23
coolant temp needle is half way when lukewarm (n/m)
tian2bing
09:14:22 02/10/23
Removed the thermostat, or replaced it? -
LitlElvis
11:05:18 02/10/23
I should have been more clear:
tian2bing
12:06:23 02/10/23
Lets Discuss..
Cjw3
12:14:45 02/10/23
Re: Lets Discuss..
tian2bing
12:41:41 02/10/23
Heater Core has no effect on Engine Overheat
Cjw3
13:23:14 02/10/23
Re: Heater Core has no effect on Engine Overheat
tian2bing
22:18:42 02/10/23
not good!
Cjw3
08:32:15 02/11/23
What bubbles are you referring to? I didn't see mention
ZXoltan
10:38:32 02/11/23
Do a combustion gas detection for CO in coolant system, >>
ZUL8TR
14:29:48 02/11/23
Common bad head gasket symptoms. (n/m)
mrchips
05:09:49 02/12/23
Re: overheating a little bit, removing thermostat fixed it
tian2bing
14:11:18 02/12/23
I'd wait on the Water Pump
Cjw3
17:28:59 02/13/23
thxs all the help. Now puddle under car.
tian2bing
02:47:31 02/20/23
Re: thxs all the help. Now puddle under car.
tian2bing
04:33:42 02/20/23
There is a common hose leak over the trans bell from the
10:47:00 02/22/23
Yup! Big 2nd (n/m)
FrozTTy
17:03:25 02/23/23
